Thanks jrsavoie, I meant IP instead of LP my bad!! I was worried about cranking it over w/the new IP spinning w/ no fuel in it. So a filled the IP up through in input line while cranking. So the first time I cranked it over to check the starter I stuck the Tech 2 on and pulled a bunch of code up see post #17 and #18. Recorded them, cleared them, because I left the PDM, OPS and GP relay wire connectors off. Then I just did a KO scan and a DTC #17 High resolution circuit, stopped for the day. So I went out there to today hooked up the connectors I left off
oop,s.
Checked all the input sensors for reference voltage, cleared #17 and unhooked LP (no fuel in it) and cranked it over for a few seconds and it hissed and popped probably because I left the plastic cover on the new TC inlet (no air
). Rechecked and no DTC,s
. Still have until Sept. 30 to return the scanner see post #17. Maybe I should have checked it w/my plug in code reader. Just need to put fuel in the new tank hook up LP and bleed fuel system of air and try to fire her up at last. Already have all the fluids in it.
Anybody out there have a good way to bleed the fuel system without a big mess? Am I missing anything on a fist start up
