MrMarty51
Maybe at a tractor supply store or something similar.Depending on how much you had to cut out, maybe use a rubber mud flap from a big rig with some self tappers and fender washers to make up a inner fender that you can re-cover that area which can later be removed for future work. That will also help protect the engine bay from road and mud debris from the tire.
Over here a farm/ranch store used to have bulk belt for hay swather/combine cross feed.
That stuff is lighter than mud flap and has like ridges to keep the clippings moving to the center.
That stuff might make a good alternative for a hole covering.
