4thesporty
^^^^FWIW, the 91 "V" trucks used a 4L80e with an NP205 passenger side drop. That might get your searching more focused.
Your a good man, I was hoping someone would chime in with a year.^^^^FWIW, the 91 "V" trucks used a 4L80e with an NP205 passenger side drop. That might get your searching more focused.
I've used the energy suspension#3.1116R on several engines. If you put the insert in backwards-end to end, it won't allow the engine to go down.[the r is the color b would be black]Here's a pic of a 4wd mount with the insert in correctlySorry I haven't updated in a while, something weird is going on my computer, not allowing me to post new topics or reply to threads or PM...
But anyhow here are a few pics of some of the latest purchases.
10 AN oil cooler lines from pmd cable.
S&B air filter kit.
New sensors and another set of new glow plugs, AC Delco this time.
New flywheel.. already installed along with block heater and oil cooler line fittings.
Engine hangin' from cherry picker...
I had set the engine in last Saturday to discover the damn energy suspension mount inserts were the wrong ones not allowing the upper mounts on the block to both set down all the way.. I'm really pissed about it.. So I had to pull the engine back out, hence hanging from the picker. I ordered some new inserts from Summit yesterday to get the lowers "rebuilt" again... Oh well.
Mike
Hi, I'm new to this forum but have had my 97 diesel for 5 years. I have been doing the same Ted's motor project with mostly the same goodies. I was wondering if you know why or what that crimped tubing is behind the flywheel. I have never seen it on a GM block.
X2. Good luck finding one. They are discontinued. I made mine.I believe what you are asking about is the valley drain for manual transmissions equipped trucks. It is designed to keep crud and junk off the clutch.
