Alrighty guys... Back on track. I did start a new job though and so it might slow me down a lil bit on this beast, but I am going to try to keep picking away at it.
Thanks to Barry "bk95td" I have received my freshly rebuilt Bosch injectors with Bosch marine nozzles and fuel line return kit. I think the pressures are all approximately 2250 psi or as close as he could get them, and he had a really nice truck pan that I was looking for.
Injectors and return lines.
[/IMG]
With the Tygon fuel return lines you'll need plenty of force to get them onto the injectors. A tip from the guy who came up with the Tygon return line idea, use a little silicone spray on the lines right where they slide over the barbs.
The Tygon line was originally suggested to me a few years back by a small engine shop owner due to it's ability to handle heat. I brought him an injector and he found the line that was the tightest fit. I bought 7 feet and went to town. Best experiment i've ever done.
I'm honestly glad it caught on. No more leaky, dry rot rubber return hoses. The Tygon line doesn't seem to have that issue.
The ones i put on my K-5 that day are still there, 2 years later. They've survived one injector swap out as well. The lines do get soft right at the injector barbs themselves when hot but right above that they seem to have no issue.
I'm very please with the Tygon fuel hose, of all diameters.
I actually used 3/8" ID Tygon for fuel supply from the frame rail fuel line to the pressure regulator on my K-5s re-done fuel system. It probably wouldn't be a bad idea to run Tygon line from your fuel manager to your IP, unless your using braided stainless that is.
Just a word of warning, the hose will conform to the injector return line barb after a while. If you ever remove them to change injectors, they will feel like they are not holding as well as they did before. The lines will sort of just slip over, instead of being a real tight fit. I don't think they'd leak(mine haven't as far as i can tell) as there's really not a lot of pressure in the return lines, but a hard accel(and i'm sure that DB4 will be able to provide you with that
) may be enough to make one leak.
