jrsavoie
Recruit
Add a bypass filter. Make that engine last forever. I prefer the FS2500
Yes sirContinue doing 3,000 miles changes
Or
Do lab tests to find out if you should do them sooner or can run longer & save money.
These??Add a bypass filter. Make that engine last forever. I prefer the FS2500
Oh copy. I have not idea if my chain was ever adjusted or not, but I was told that going off that mark indicator was the way to go, and that since the two notches line up, it should all be goodThe marks should line up when there is a new timing chain. As the chain stretches the timing is supposed to get adjusted. Gm called for 50,000 mile intervals but all the fleets and shops learned 30,000 is a more realistic interval. Doesn’t usually take much, width of a dime each time is fairly close for most. Using the timing gun is the proper way.
