buddy
FWIW and to others, taking the passenger side wheelwell out takes about 5 mins with an air ratchet and then it's much ,much easier if you did'nt have it out already from the HG job
Very True
Thanks! I didn't ANY trouble with the stock turbo, it lined right up perfect. this one is there but at certain RPMs i get a vibration, the pipe is in there pretty tight as is. I'll remedy that one day with 4"I have trouble lining the downpipe up with either turbo, done it several times. Although its partly becuase passenger motor mount is sagging a lot.
Best of luck on the maiden voyage and your move.
Thanks Louis, I'm hoping so. I'm hoping that everything works out for the best on this pig. And the airbags are doing their job as we speak (leveled the truck out after loading it and throwing the trailer on it).Your Rig is ROCK Solid now and you should have a substantial amount of piece of mind, for this or any other long haul trips.....Enjoy it!.........You deserve it!......You've done a great job and repaired every issue methodically, without taking any shortcuts, again superb job with everything David.
FWIW, I really love the air bags and the on board air with accessories.
I considered taking it out, however the rubber liner has been missing since I bought the truck, and I just used a few wobbles and got everything out of there. Wasn't a biggie for me.FWIW and to others, taking the passenger side wheelwell out takes about 5 mins with an air ratchet and then it's much ,much easier if you did'nt have it out already from the HG job
Youre absolutely right, that stock exhaust wont let the ATT spool enough, I and THMark had that same experience. It will perform way better when you open it up. It really wont work with a cat, so I imagine you dont have one, because I could lay smokescreens for miles and could only get 5psi boost max when I had one. Ripped it off right quick. You will feel way better about that truck after the 4" exhaust.
