88gmctruck
02GMCtruck
Well... It's together.
And it didn't blow up.
After getting 99% of it together and priming the injectors, it was time for the engine flush. Without the turbo attached and the turbo oil feed in the oil filler, we flushed the oil system. Used 7 quarts of off-highway #2, 1 quart of ATF and a new filter. Let it idle for about 2 mins or so, then drained it out. Filled it with 8 quarts of 15w40 Castrol Tection Extra Diesel Oil (typically I run Shell Rotella T but this was on sale and it's only going to be in there a short time compared). Bolted on the turbo after a bit of fighting with the return tube...
Fired her up. Sounds perfect at idle. It's all clattery clanky like it should be. After letting it idle, checking for leaks, etc, it's time to give her a test spin.... Pull out onto the road, give it throttle and boost builds... *whirrrrrrrrrrrrrr* (and not in a good way)..... Crap.
The turbo is munched. We had some issues with the shaft and are pretty sure it's bent a little bit. IMO it doesn't spin straight so it's probably a ticking time bomb. Over 1,000 RPMs it makes a hell of a spooling sound, kinda like a shop vac. Brought it back home, let it idle up to operating temperature to bleed the cooling system, etc. Everything, except the turbo checks out. My oil cleaning job did a very good job, even after the truck ran for probably an hour, the oil is still honey colored and clean. I'll be keeping a close eye on it and seeing how it changes over time.
So, I'm looking for a new (used) turbo now too. Anyone have an affordable lead on a GM-8?
