Rockabillyrat
SlIgHtLy StUpId.
Have you ever tried a quick spool valve on the 18cm? The only advantage to running a twin scroll housing in a open system is you can close off half the turbine with a spool valve to help it spool in the lower rpms. Then the valve opens and allows for full flow through the turbine housing when you reach your set boost level.
