At the top of the page is your icon and name. Click on that, it will bring up this list. At the bottom of the list..View attachment 64337
Got it figured out. Thanks
The 14cm housing is just a little to small for the 6.5 if you work it hard. And the 16cm is a little laggy with the factory open exhaust system. If you built a divided exhaust setup it would increase spool time on the 16cm, and lower EGTs as well. Probably be the same amount of work as a compound setup. A divided system could be side mounted, or buy van manifolds and build a center mount.
My sxe362 shipped a few days ago. Im hoping a divided system will spool it with a .83T4 nicely.![]()
Have you tried running something other than the factory twin scroll housing? Switching to a .70 or .80 t3 open might help get you EGTs down, and have good response. The .70 would be a good fit since your running a manual.
I'm open to any suggestions. Where would you find something like that?
I pulled 6.4L PowerStroke compounds for my P400 project. Steed Dolan’s Banshee VGT controller is compatible with the Ford VGT servos after a firmware update, and you can get an aftermarket servo that doesn’t need liquid cooling.
Not sure why more people aren’t considering this option. Ford’s compounds were sized by P. Eng’s to efficiently fit a close power band (~350hp) and displacement (6.4L) to what a built injection pump on a studded 18:1 6.5L can do.
Also what base timing are you running? The DB2 doesn't have a large timing curve. The pump is physically capable of 11-12* of camshaft advance. But due to the LLA armature is only sees 3-4*. Advancing your base timing will help lower EGTs and improve MPG. but it also increases cylinder pressure so be reasonable. I'm working on some parts to redesign the DB2 timing curve that should be in testing this summer.
Well the reason to run compounds for towing is to increase the air volume with the bigger turbo to lean out the air fuel ratio thus lowering EGTs. Running two of the same compressor sizes wont help with that because the CFM/ pressure ratio is the same on both turbos. so your not getting the extra air you need to lower the EGTs.
