ak diesel driver
6.5 driver
No what I'm saying is the vacuum before the turbo increases with more boost (the vacuum also can be can be changed by how far or close to the turbo the tube is placed) and it's that pressure differential that closes CDR. From the testing I did it only really closed at WOT and then only until crankcase pressure forces it back open. When you say high RPMs your basically saying vacuum. So to sum it up IMO the CDR only does anything at high RPM or WOT and then only until crankcase pressure opens it back up, the rest of the time it's just a pipe the connects the intake and the crankcase.
