Will L.
As to replacing the rings but the block being cracked-
The heads have to come off- the crankshaft could stay in place.
But by time you remove both heads, knock the pistons out, install new rings and put back together- not many folks do all this and not rebuild everything while there.
Pickups make an inframe really hard. Water shock clean by doing water down the intake trick to begin so you aren’t fighting pounds of carbon. Pull both heads, Jack the engine enough to remove the oil pan. Undo rod nut and drive out pistons. A fast ball hone swipe, throw on new rings after gapping them- hopefully realizing gapless is the best chance here. And slide it back together.
Maybe new rod bearings just because they are already out- if oil pressure was great and money is not- reinstall the originals
Super goop from our friends at permatex the pan on.
Drop back into engine mounts, new head gaskets and new head bolts are not an option.
Will the compression be perfect- is it a proper rebuild? Nope. You just brought things a whole lot closer to spec.
But this is something best done when a standby truck can take its place if something goes wrong. Its a lot of effort to save some oil, usually reserved for too low of compression to start scenarios.
