buddy
Active Member
I like GM 350s, I have one in the Camaro and of course in that its powerful as all heck, but I enjoy working on the 6.5 a lot more.
im not advocating buying a gasser but those 5.7 vortecs are no slouches in reliablity for a gas engine. my neighbor who has 3 kids needed an extra vehicle so they bought a clean 1996 tahoe with 210k miles for 2k dollars. all it needed was a radiator and spark plugs and away it went. been running good ever since.
The 350, 5.7L, is like a McDonalds cheese burger. Millions made. So simple that anyone can work on it.
The gas engine will take more punishment and abuse than the diesel. Parts are cheaper. Diesel prices are high and more MPG does not mean less cost per mile anymore. This is the only reason you look at a complicated diesel. In my case towing a 350 would get 6.5 MPG where the diesel gets 7.5-8 MPG but 20 MPH slower at times.
So the gas engine blows up at less miles than a diesel – I am not sure that is anything less than a rumor for light duty diesels. (Maybe for the Duramax generation stuff.) Forget to change the damper or overheat the 6.5 diesel once and you are changing it out for total engine destruction. Every repair is major and expensive vs. the gas guzzler.
Even replacement engine cost is cheaper for a 350. Try and find a rare 6.5 at a junk yard and they are propping the front door open with a good 350.
You can but a lot of premium grade gasoline for the cost of major repairs to diesels.
A better comparison would be the 350 vs. a 454. The underpowered 350 has to work hard all the time. A 454 will get better MPG until you push it hard.
Probably the best way to go moneywise would be a 350 propane. You get a cheaper parts, cheap fuel, good mpgs, and more power then gas.
I think you might be confused:rolleyes5:
Propane has less btu's than gas, therefore less power. Propane-fueled engines HP are de-rated from their gas counterparts.
1993 "Clunkie" Cash for clunkers escapee. GMC 4x4 Sierra 2500 6.5TD ext cab long bed. 4L80E reman. 4.10 Rear. DB2 Mechanical IP 1/3 turn high. Factory no kitty/soot trap! 4" exhaust. Turbomaster 14 PSI max. Kennedy 9 blade fan and clutch. HO water pump. Single 180 stat. Trax II 50 gal in bed tank.
Who needs all 8? Hits on 7 of 8 - rest blow into the crankcase. Engine oiled on the outside better than the inside!!! Soon... Military surplus 6.2 Repower. The vehicle the 6.2 came from was then BLOWN UP on the target range!
Wow. That's quite an indictment on the 6.5 Diesel. If this is all true, then why do any of us actually opt for a 6.5? Are we just dumb?
-Rob![]()
Because it pulls harder and is more efficient when set up properly
I knew that, thanks. I was being sarcastic, and was surprised by the lack of vitriol at the comment that a gasser is demonstrably superior to the 6.5. I'm still rather surprised that few people have jumped in to defend the 6.5!
-Rob![]()
wow, 93-99 gas 1500 Subs are a dime a dozen around here. They were so popular the used market is flooded with them. You'd have to work at it to spend more than $3-4k for one around here, and I see them for a lot less with miles on them. I would keep looking for a gas Burb cheaper than that one. Seems way high to me.
As for the diesels, they are super-rare around here. Almost never see them, sometimes they come up at a good price, sometimes they are real high.
-Rob![]()
My boys and I leave tomorrow morning for a camping trip. The seller of the '96 suburban is meeting at the campground. Hopefully he will leave with my pos camry and I leave with a nice new-to-me 6.5l suburban and a lot less cash. If it happens, expect pics on sunday. Wish me luck!![]()
Make him thing youre bringing guns too :AR15firing:
good luck, sounds like a good deal.
