About to mount my fsd from ssd on intake as recomended. So cant answer you for another 100,000 mi. I will say ssd has not steered me wrong on anything. Tech support is the best in the 6.5td buisness. From what I understand its not engine heat that cooks the pmd it is its own worst enemy. Cooks itself. So keeping it in airstream of engine fan with heatsink is the only way to keep temp down. As soon as you park the heat stays with it. By letting truck idle a minute before cutoff fsd can cool off a bit. Air temp wont cool that much where I live in mississippi. It would still be 90°-110° all day and just get hotter parked in sun after driven. Ssd tests products and has the first patent on cooler for fsd. Read about fsd pmd failures and you will see they fail in all possible locations. Older ones are inferior to updated ones. Ssd carries the newest version available. Even so called bulletproof one fail in bumper. I have researched as much as possible on this and my conclusion is carry a spare or go mechanical ip
My fsd kit is on Aluminum L bracket, fins forward behind driver side battery. It is currently in process of failing. I have to pop the hood and drive like that so it cools off. Have a new one from ssdiesel but my concern with mounting it in bumper is that a minor fender bender put the truck down in a heartbeat. Looking for other options?
Not a salesman,not cheerleading just my oppinion guys. Ssd has been great to me on everything else. As I said that was from what I understand about pmd/fsd failures. If mine fails ,again,I will post about it to help others thats what this is all about. I appreciate the advice leroy,you seem very knowledeable,i mean that. Dieselcash I have done my homework, please dont be rude. "yay yay,ssd all the way,yaaaaay diesel! Jk. Lmao!
Leroy diesel has a wonderful rep and im sure I will do buisness with him in the future. Dieselcash I was wondering if you have had any ssd parts or is this speculation? Also on that 93 I assume your running a mechanical ip so is fsd failure even a problem for you? I am here to learn and I learn new things everyday. I have spent a lot of $ on ssd so for my sake I hope your wrong. So far I am very pleased with them.
Glows I got from ssd are acdelco
Should be good, as Leo said 60g is the best a/c Delco.Glows I got from ssd are acdelco
Thank you, I try.Marine inj I got from ssd are bosch so maybe they shaped up since then. Idk. But I am very interested in the fuel filter you offer leroy. I like the idea of removing my fuel sock. You have very innovative products
Leroy you also suggested behind blinker on core support as another option? Fins horizontal? I plan on making new bumper soon. My cuz does amazing metal fab for jeeps so we are making a beastly bumper for sub.
