- Staff
- #241
I have the same issues on download times.
The two major limiting factors to upload times to YouTube are your upstream speed of your Internet connection and the amount of compression/resolution of your video. An MP4 encoded 480p 4:3 a/r mono video will upload much, much faster than an AVCHD 1080p 16:9 a/r with a Dolby 5.1 surround soundtrack (like I shoot my live music video in). With a 2Mb upload connection, it takes me about 45 minutes to an hour to upload an 8-10 minute video (about a 1Gb sized file).Any one know how to speed up the download time to Youtube? This 8 min vid took 75 minutes!! (pretty typical times for me)
BEEF and heat treated valves and valve seats.What's the difference between P400 and Optimizer heads?
It is possible for the gaps to align, but I don't dont think they ever will. When they are compressed in the cylinder along with the friction of the thin ring against the surface or the 2nd ring it should not be moving. Also I've never "heard " of it happening, but I did not actively search that info.With the gapless rings is there anything to keep the 2 different rings from rotating with vibration and what ever and aligning the gaps.
OR is that a worry? Or if they can rotate is it like a clock and only be aligned at one time and will rotate more and get out of time????? And odds are they will stay out of alignment most all they time?
Did you have to size them anyway or out of the box and install?
Im so ignorant to those type of things. My camera has a "video" mode, not sure if I can change the resolution on it. I do have high speed internet connection.The two major limiting factors to upload times to YouTube are your upstream speed of your Internet connection and the amount of compression/resolution of your video. An MP4 encoded 480p 4:3 a/r mono video will upload much, much faster than an AVCHD 1080p 16:9 a/r with a Dolby 5.1 surround soundtrack (like I shoot my live music video in). With a 2Mb upload connection, it takes me about 45 minutes to an hour to upload an 8-10 minute video (about a 1Gb sized file).
Isn't that color Husker Red? LOLBright red.
Not much at this time. Going to look into "oring'ing" the head studs today, roller rockers and studs. Thats about it.What are you doing to the heads?
