pacificdrumma
In regards to the trans, some 1500's had 4L60E's and some had 4L80E's. Im guessing that GM wouldnt put a 60 behind a 6.5 cause they do make SOME torque.
Sorry it took so long to get back in here fellas, I get busy this time of year. I have had my truck since 98 so I am no stranger to the 6.5. First engine was replaced at 70,000 with a crack down no. 8 cylinder. It wasn't a knock on the ATT. It is definately an improvement over stock and the second best turbo I have had on the truck. I had an ATT for 2.5 years and wanted to try something different. I liked the performance of the Holset empty and towing better so it stayed on the truck. It's a real holset not a knock off and still have only about 550 in the setup including the turbo (turbo was new with a billet compressor). I also like knowing what is in it and can go to any holset dealer and get parts if necessary. The parts in mine are individually balanced and if I decide I want to change the compressor and housing to see what will happen, I can. One of my biggest concerns was if something happened to the turbo and Dennis for some reason had to quit supporting it, where would I get parts or get it rebuilt? My comment was directed on the advice being given on EGT temps. If someone wants to run that high on their personal truck it doesn't bother me in the least, just don't tell others it is ok without a disclaimer or warning. My sig and avatar were meant to be amusing.
Sorry for the confusion. I've always assumed it was a 4l80e, I wasn't aware they put any other auto behind these in 1995. Plus it's 4wd and has taken plenty of abuse. I wish I had a nv4500. Peace of mind is the main reason. 2nd being manual is way more fun to drive.
Well, now that I have a turbo that can utilize higher rpm fueling thanks to a literal "choke point delete", I do believe it has helped. It's one of the cheapest mods you can do, along with a good lift pump like the one I got from Burning Oil, that will ensure your fuel supply system isn't putting any strain on your IP, just lettin it do its thing.
You get the lift pump in then? is the run in vid with new LP?
All factory trucks with auto and 6.5 had a 4L80E.
Well don't I feel like a dumbass. I took my dirty k&n cone off and cleaned it, now I'm getting 20psi and my egt's are topping at 1100. I'm a happy camper. Uploading vid to YouTube as we speak
I didn't see it mentioned but if you can you should run a prefilter. I killed my frc10 in a little over a year by not having one. Ran intermittent then just quit. When I took it apart it was all scored up inside. I had a frb5 before that and I hope it is still running good for Tanman.
I am a machinist not a writer and don't always get what I am trying to say across. I don't have any proof high egts kill engines and have no doubt that ATT can take the heat. I just know from my experience with Att he shouldn't have been running that hot empty unless something was off. I was just thinking someone should be telling him things to check instead of telling those egts were ok. I was trying not to start a disagreement by contradicting you and knew Dennis or Tim would be along soon to help. Since I don't have an ATT anymore, didn't know if my advice would be welcome. Mine ran a little warmer but still not that hot when new until it broke in and loosened up a bit. It was stiff out of the box. After he cleaned his filter he came in line with what I saw.
High egts would concern me for a few reasons. Heat transfer to heads causing warping and head gasket problems with the tty bolts especially in heads that are prone to cracking anyway. Could also mean there are other problems like injectors are worn. Could also mean not getting a good burn in cylinder which may lead to wasting fuel and leaving power on the table.
Strangely enough as you advance the timing the EGT goes down. (So does turbo spool quickness from lower heat in the exhaust EGT.)
but, change the timing to retarded and EGT's go way up and power/stress goes down.
