6.5L
Old Iron Runner
Why?
Some of us are wondering why that comment was made. Like you said, a reflash and you''ll be fine. Modifications will require tweaking, then it will be awesome. I had a few minor issues with mine like the fitting at the turbo weaping and finding fittings to get the cdr line under the intake hose so it would'nt rub the hood insulation. Keep up the positive attitude
I still am waiting for a definitive answer from Monarkman.
I feel bad for you OP. I feel bad for the people involved every time I see one of these threads.
You shouldn't. I'll tell you what you should feel bad about: Closed minded trolls like you cost me a bunch of fuel money by stomping any information about better turbo's for as long as you could. The high EGT myth I get sick of reading about.
Finally when the evidence was overwhelming you had to admit GM screwed the pooch with the factory turbo.
As it is the ATT and HX40II generate the same HP on the rollers with the ATT using ~10PSI less boost.
I will encourage the trolls with "My Turbo is bigger than your Turbo!" :hihi:
I even have a friend that owns a 93' 7.3l idi and a 91' 12v cummins single cab flatbed work truck and he asked me if this turbo would work for him . . .
