n8in8or
More progress. All of the pistons are in and the heads are on. ARP studs were torqued in 3 stages: 70, 90 then 110 ft-lbs. Also I used the Fel Pro +.010 gaskets so with the -.010 pistons I should be around 19:1, but I don't know exactly. Oh and yes I'm a dumbass and put the heads on backwards from how they were so now I need to move my blockoff plates and sensor/plug.
Check out the othe addition while the engine was apart: a DSG stud girdle. I figured it was good insurance.
I also started installing some more shiny stuff on hoses and ac lines in case that header puts out more heat than the manifold.
A new transmission input seal also went in.
The engine should be all together tomorrow night and ready to stab in the truck Thursday.
While we're here, I know there are as many opinions as there are belly buttons, but what do you guys like to do for break in? I searched it before and saw wildly varying ideas, but if anyone wants to share what they've done in the past I'd be happy to listen. As I recall Jay had a pretty good one but I can't remember the details of it now. Thanks!
