SnowDrift
Ultra Conservative. ULTRA!
Assuming you find all the rest of the parts.
How about slicing the material with a utility knife, or a single edge razor blade would make a thinner slice, wherever You want a butted together seam, then apply the tape if so desired.There is a seam tape I discovered and taped up all the seams. It's supposed to be good for a few hundred degrees. I'll be a believer if it still looks this good after a few hundred engine heat cycles. The irregularities on the firewall shape made this a real challenge. I estimated about 12 hours in the whole job, but that was also including a few dozen trips into and out of the engine bay when fitting the cardboard pieces. For the holes, I marked them and punched through with a long stainless screw, then hand turned a drill bit to open the holes further and to chew away the fiberglass mat underneath the aluminum surface.
I had some overlap on my sections. If I had to do it over again, I would have likely butted them into one another. We'll find out later if it matters, aside from appearance.
