Will L.
Imo, leave the turbo alone for now. You are showing good oil pressure when the fuel cuts out so I would believe good signal from ops is present. TPS means nothing here because it is dying at idle.
You NEED clear line on return of ip to see if there is any air getting sucked into the fuel system. You also NEED a fuel pressure gauge (that also reads a vacuum) off a tee just before the ip inlet that you can read while driving, when it has the problem what is that pressure or vacuum reading.
After getting that reading when the problem occurs you need to read the pressure vacuum before the LP when the problem occurs.
Anything else you do at this point only going to muddy the water.
