93 6.5 help plz
so at this point I would think you need to verify fuel pressure at the IP. If it falls of there move the gauge back behind the FFM. If it falls off there I'd be double checking all the LP stuff again and after that drop the tank to inspect tank pickup sock
Personally, I will get an ACDelco OPS.
I am not sure if the LT warranty from OReilly is ACDelco, I suspect it is not.
For the aftermarket brand, you have to use the Lifetime warranty a few times before finding a good OPS.
None of the local part store usually stock ACDelco anymore other than the stealership.
I got mine from RockAuto.
Is this for the 93 or 96?
93 I'm going to check some of the grounds on the back of the engine I'll have a link of a few videos up I'm a few also
<embed width="600" height="361" type="application/x-shockwave-flash" allowFullscreen="true" allowNetworking="all" wmode="transparent" src="http://static.photobucket.com/player.swf" flashvars="file=http%3A%2F%2Fvid850.photobucket.com%2Falbums%2Fab70%2Fbgbengalsfn1%2FMobile%2520Uploads%2F20150222_161633_zps5zpdhrjg.mp4"> this is a video of cold start running alright
Fill out your signature.
Is it 93 or 94? Seems like your running out of fuel. What psi are you getting from LP?
Ok didn't drop tank don't want too unless I have to so I cleaned out fuel lines with bout 110psi of air runs great for now so going to run it low on fuel drop tank clean it get a new sock and pray I don't have any more problems till next year lol
OK I've replaced lp ip ops alternator fuel filter new batteries i know tps is bad just don't have the extra for that right now but I'm having what seems like random stalls and surges any ideas of problems and easy fixes
