red
Being a lake bum in Texas
Made the first set of cuts for the rock sliders that will be added soon, sadly found more rust than I was expecting inside the rocker panels
Little bit of time with a steel wire brush and things are cleaner. Outside the rockers alot of what your seeing is mud
Here at the trans hump was not rust but alot of thick grease, decided to hit it with the brush to speed things up when I sand or blast the underside of the cab
