n8in8or
That reservoir is most likely polyethylene. I work in a plastic injection molding plant.
I wish I had this info earlier. I installed the reservoir Monday night. Tuesday morning there was a puddle of windshield washer solvent on the garage floor. I did more research into gluing Polyethylene and yeah, it's going to be tough getting the joint between the PE and PVC to seal. I'll try some more things to see if I can get it to seal, but I'll likely be making a new attempt at it after I find some PE pipe to use instead of the PVC and then weld the 2 together.Pvc will not weld to PE and solvents do not bond well with PE .
