n8in8or
Thursday night I repaired one of the connectors for the defroster on the back glass. I bought some electrically conductive epoxy off of Amazon that had good reviews.
I sanded the old adhesive off the tab and cleaned the tab and the window glass. After mixing the 2-part epoxy it looks like molten solder.
I put it in place and then held it there with masking tape.
Last night I took the tape off. It feels snug.
I reattached the wire so now that should be set.
Last night I also did the 500 mile oil change. I’m enjoying the truck so far, but VERY interested in putting the 4.11 gears in it to make it feel snappier. I’m going to start doing some documebtation of how the 3.42s work so I can make a good comparison between them and the 4.11s and decide what direction forward makes the most sense. I need to compare not only acceleration, but also mpg (city, 55mph backroads and highway) and NVH comparisons at various speeds. The calculator says my highway rpm should only go up 400 rpm, but that may be enough to be annoying on a road trip.
I also balanced the rear tires last night. It has a vibration at highway speeds and it felt like it was coming from the back. It’s better, but still there so I’ll do the front tires next. If that doesn’t do it then I’ll have to take a look at the driveshaft I guess.
One more thing to note: every once in a while, when I start the truck after it’s been sitting I get a healthy puff of oil smoke. Not every time, just sometimes - so far it seems random. My best guess right now is that I have a bad valve stem seal on an exhaust valve, but I’m still just keeping an eye on it. I’m not looking forward to tearing into it to make that repair so I’ll make sure that’s what it is before I do it.
