Husker6.5
I forgot that the GMT-800's and later had Bose systems. Can't beat Bose.
I believe its 37 or 37.5 gallons.What's your fuel capacity with that Yukon?
With rocking of the Burb and burping of the tank, yes. I've done that with all the vehicles I've ever owned for two reasons. 1) Maximum fuel capacity (that extra two quarts could keep you from a twenty mile walk). 2) Consistency for mileage computations. The only vehicles I've encountered that you can't do it with are the newest Ford capless fillers like on the Focus. After the nozzle kicks off, you can only put in a few tenths before it starts dumping fuel on the ground from somewhere above the tank/on the filler neck.Haha. That’s great. Filled up the filler neck to the brim ehh?
Nothing like handing a customer a $600+ estimate to fix there fuel smell because charcoal got into EVERYTHING from them brimming the tank. And they would scream it's under warranty, but warranty doesn't cover negligence on the owners part.You really shouldn’t do that with gasoline rigs.
The canister can fill with fuel much sooner, instantly in some designs, and your replacing it just from that. That’s the reason the signs and stuff say do not top off.
Forgot to mention since the conversion, I have racked up 12,830 miles so far.Well rig is still running well. I've got a pretty good leak at the fuel cooler. Probably the seal/oring in the quick connect fitting. I'll be tearing into that this weekend. I noticed it a while back but it wasnt actually dripping onto the ground. it was just wet underneath. Its got a nice little puddle now so I can't ignore it any longer. I'll try to get pics and update after I tackle it this week.
That unfortunately isn't that uncommon. Many cut the quick connects off, replace the fittings in the cooler with hose barbs, and put the hose on with clamps.Well rig is still running well. I've got a pretty good leak at the fuel cooler. Probably the seal/oring in the quick connect fitting. I'll be tearing into that this weekend. I noticed it a while back but it wasnt actually dripping onto the ground. it was just wet underneath. Its got a nice little puddle now so I can't ignore it any longer. I'll try to get pics and update after I tackle it this week.
Yeah I think thats what I'm planning to do. do you recall the thread size on the cooler? looks like 1/4 NPT? Maybe 3/8?That unfortunately isn't that uncommon. Many cut the quick connects off, replace the fittings in the cooler with hose barbs, and put the hose on with clamps.
