BigDogYJ
Sorry your question got lost in the posts. Better late than never.Nice project......just one question; what capacity is shown on the placard of that 2500 suspension on the Burb?
Sent from my iPhone using Tapatalk Pro
Thank's, I suspected you were busy w/travel etc. I see it's an 8.6k platform which is good & that is a real nice drive train too.Sorry your question got lost in the posts. Better late than never.
If anybody is interested, your engine, trans, transfer case, harness's, pedal, pcm, and tac module are for sale on facebook marketplace for a STEAL! He's got it all up for $1700.
https://www.facebook.com/marketplace/item/256476121556922
So I tore into the brakes this weekend and got all new pads and rotors installed. Rotors were definitely heat scorched and contaminated with oil of some kind. Got that all swapped and hooked up a Snap-on scanner to run the ABS automated Bleed. Ran that a few times and pumped through almost 2 quarts of brake fluid. No more air and the brakes actually feel like I remember them. Glad that’s all fixed up. They should get a little better as the pads bed to the rotor.
Bosch Quietcast rotors and pads.
FM modulators (just like FM broadcast) compresses the signal so you loose both frequency range (very lowest and highest pitched sounds) and dynamic range (loudness) compared to a direct from source input. You also can get background alternator whine/ignition static/switch 'pop' from FM modulators due to ground loop induced noise, not to mention "walk over" from a strong FM station adjacent to the modulator frequency(s) or a weak/distant station on the modulator frequency(s).Have a couple of FM modulators. Both of them result in a signal loss where the audio is clearly not as robust as a direct signal.
Toward aftermarket audio systems in the GM. I had looked but never found any that allowed for speed inputs and decided to stick with OE.
I didn’t see an option for one with pre outs. But it currently has a decent bose system. I might attempt the lux upgrade as I got a hold of a lux amp a while back. Apparently the stock headunit can be reprogrammed to work with the lux bose amp and that is a very nice sounding system.Do they also offer pre-amp outs for hooking up outboard aftermarket amps for your head unit? You may find someday you might want to add sub(s) or just better, higher powered amps than what's in the OEM factory head unit.
