red
Being a lake bum in Texas
Is that fuel filter mounted upside down ?
Can't see it in the picture but at the bottom of the metal section there is a drain for the water separator on the housing, it's right side up. Wondered the same thing when I first saw it on the truck haha.
Couple items should be here tomorrow for the truck. 60G glowplugs, glowplug removal tool, FRB 5 lift pump, mudflaps. Already have 2 winches and another fuel filter base sitting here waiting to be installed on the truck. Plan for the weekend is to secure the flatbed to the frame, maybe remove it's wheel wells, install the mudflaps, then fuel system mods. Going to relocate the current fuel filter base to just over the fuel tank and plumb it in as a primary filter. Then the FRB 5 lift pump will be mounted there as well, and a final filter mounted in the engine bay using standard spin on filters. If all that gets done then the rear driveshaft will get taken care of and the glowplugs after that.
