dbrannon79
I'm getting there!
do the relay mod so the power draw isn't going through the OPS.
Prime example why you want fuel pressure gauge attached right at the ip in metal fitting.
It would have shown the lack of pressure from the hose pinch.
Idk. My suggestion is call Mod Mafia and ask what sizing theirs is if it is for FTB or not. I still haven’t seen anyone else selling the parts.
Other than that take your fittings out and down to a hydraulic shop, or place like summit if you go through Reno when you travel better Ca and Mt.
You Do NOT want the thin aluminum A&N brand ones if at all possible. They are thin for light weight racing and we need heavy duty to fight vibration.
Finding the part is the hard part and why most folks pay the extra $- it might take several hours going to different stores to get what you need unless they can identify size and such for you at the first one if they don’t have it. None of the Autozone type places will have that.
Db2 is easy- just a street T in 5/16 or 3/8 depending if someone upgraded to the 3/8 ford cone or drilled and tapped theirs. Ds4 has some odd thread iirc.
Maybe it’s easy to find? I hope for you anyways...
modmafia.com
Electronical fuel pressure gauge is fairly easy to find.Still having difficulty visualizing where the heck the Mod Mafia fitting goes. How does that get me a T-fitting for the gauge? What would connect to the IP? Where does the T-fitting fitting look like and where would it go? Does this only work on rubber hose set-ups. How do I get it to a gauge in the cab without running live fuel hose in there? Has anyone done this that can show pics or video of the set-up?
Fuel Pressure Tap (FPT)
This item makes it very easy to add a fuel pressure gauge to your 6.5 equipped vehicle.modmafia.com
The fitting threaded into the filter screen in the IP is a #4 oring boss hydraulic size if that helps. if you were to get a make #4 oring boss to male #6 AN (37 deg flare) fitting, that fitting you linked would screw right to it and have the port for the pressure gauge.
If your going feed the beast mode, you may want to drill out the inside of the make #4 oring boss side of the fitting as the ID will be around 1/4" since the fitting will be rated for high pressure from a hydraulic stand point. you should be able to bore it out to around 5/16" or so.
www.glowshiftdirect.com
The problem with the one Marty shows is that puts rubber hose between the ip and the gauge sending unit. It would work, but when that rubber hose fails internally, you wont know the ip is being starved because the gauge could get pressure still.
Use an electric gauge not a mechanical one.
Here is a sending unit and gauge as example. There are better gauges- thia one is just first to pop up on a search.
Tinted 30 PSI Fuel Pressure Gauge
GlowShift Tinted Series 30 PSI Fuel Pressure Gauges Monitor Car and Truck Fuel Pressure From 0 to 30 PSI On An Analog Display to Confirm Levels Are Optimal.www.glowshiftdirect.com
