snarl95
Replaced rear u-joint and rear brake shoes.
Not a tough job to install new seals into the old calipers.Started on rear brakes on the 2014 4Runner after arriving at our Montana home. Encountered problems loading the pads into the calipers and ended up breaking off half the friction material on one pad. The tabs on the pad just would not go in on the piston side of the caliper. The calipers are Raybestos remans. Probably should have ground material off the tabs on the pads.
I have new pads ordered at the local Napa which opens at 10:00 am.
Appears that the metal worms get a nice start on them rotors.
Does it have a snubber?Drove the diesel truck to church today.
That fuel pressure sending unit next to the IP is acting up again.
Guess I’ll next remove the sending unit wire from the toggle switch and wire that sending unit direct to the gauge, then I’ll be able to determine if it is the sending unit or the toggle switch causing the gauge to go wonky.
Just not right at this moment. I need a nap.![]()
The Napa pads were tough to get in.Sounds like the Chinese copiers making the pads didn't quite get their copy quite right LOL
No.Does it have a snubber?
Maybe try swapping sending units out and see if the wonkyness follows it.No.
The sending unit at the AD pump functions just fine.
This sending unit is post FFM AND I didnt think there should be so much fuctuation between the FFM and the IP.
I already replaced this sending unit once and this one seemed to be working nice and steady at the gauge for a while.
After I get the Triumph finished I’ll try bypassing the toggle switch with a hard wire to the gauge and if that fixes the fluctuating gauge then I’ll try a new switch.
If it dont then I’ll get out the mechanical gauge and plumb it up to the windshield wipers then take the truck for a drive. See what that does.
Although, at one time on my way home, the front sender had the gauge reading near 15 PSI, I didnt think to flip to the back unit and see what it was reading back there. Although that sending unit has been right on with no fluctuation whatever.
I could switch the sending units around and see what they do but would have to pull the upper intake to get enough room to remove that sender and get the other screwed into the fitting. Very little room on that one.
Yup. Right after I try the direct connection between the seemingly bad sending unit and the gauge, by passing the toggle switch. Then if the gauge functions as it should then I’ll replace the toggle switch.Maybe try swapping sending units out and see if the wonkyness follows it.
