n8in8or
Another nice thing about hot dipped galvanized is that it's UV stable after being coated. E-coat is not UV stable, so it needs to be top-coated anywhere it's going to be exposed to UV rays.
Hot dipped frame?I've read of guys living close to the shops that do it getting it done anywhere from $3-800
Why didn't someone tell me that 46 years ago?
I don’t know about that, but I appreciate the compliment. Thank you.A work of art.
Thank you. Most of it turned out how I wanted, but a couple spots I wish were a little better. Good enough for who it’s for though!Sweet looking welds, Nate!
Incorporating a nipple always sounds like a good idea.Thinking in My head of a way to ventilate the frame so that if there would be humidity/moisture gather within, that moisture could easily evaporate out to the atmosphere.
Thinking maybe several of those crank case filters that were placed inside the air filter housing of the GM vehicles, held in place with a clip to the outside of the air cleaner and a coupler a hose shoved over that went to the valve cover, might be a good answer. Incorporate a nipple to the frame, a hose attach to that then with a filter on the end of each hose would keep out bugs and debris and allow the frame to breathe during warm and cool spells.
Just a thought is all.
The hose could extend upwards to an out of the way place where water and dirt would be less likely to get splashed and cover the filter end.
2 lb density closed cell is moisture resistant.looks like a masterpiece. curious on how much heavier the frame is with all the boxing
with foam, I would be afraid of it retaining moisture when the frame isn't sealed off.
1/4” plate is about 10 pounds per square foot. A lot of the rails are 8” tall, but then they taper at the front. So maybe roughly 12 feet at 7”? (this doesn’t count the rectangular tubing at the rear) That works out to 14 square feet. So 140 pounds maybe? I know it’s heavy….I lifted the rear with the Turd Ferguson and it was all it wanted to do - now I have the snowplow on the tractor so that’s using up capacity, but still, it’s definitely heavy.looks like a masterpiece. curious on how much heavier the frame is with all the boxing
