ak diesel driver
6.5 driver
I think you need a couple more vehicles in there LoL. I'm envious of that much space.
I slid the whole hoist and truck across the floor in the lowered position using my tractor.How did you get the blue and silver Tahoe over there on the lift?
Yeah, you can buy brackets that will bolt in place of the 2wd core support mounts, but so far that appears to be the easy part…..installing the 4wd crossmember and motor mounts are going to be the hard part - now I will say, this is an optional step for a 4wd conversion, especially if it’s lifted, but that’s how I wanted to do mine, so I’m causing myself more grief than necessary…….as usual…….I have read articles of people converting the C frames to K frames by adding the leaf spring mounts for the front axle to the C frames. I doubt that they knew that such a difference existed.
GMT400 (88-98) is a different ball of wax. What I was referring to are the brackets like these that ORD makes for the squarebody trucks.Would anyone know where to find such bolt on brackets? I would love to get rid of my coil spring front end and use the torsion bar setup that the 4x4's and newer rigs use. I wouldn't go through the complete conversion though, just the front suspension system. there is so much more you can get and do with that style.
And then, finally, finishing up the skid steer?Once I get past the Frankensquare, I can get back to the red truck. It would sure be nice to not have that taking up space in here. Then on to the original Tahoe…..
At this point I probably never will, just to spite youAnd then, finally, finishing up the skid steer?![]()
Nah, you know it will always be nagging at you in the back of your mind as the project you never finished! Remember, you bought and started rebuilding it to rebuild your retaining wall - which you've already rebuilt with with other equipmeny you got, because the skid steer wasn't done! You'll wake up in the middle of the night from nightmares of the skid steer calling to you, "Na-ate. Na-ate. Finish me! Na-ate!"At this point I probably never will, just to spite you![]()
I looked at the photos over and over trying to determine the method you used to accomplish that. This isn't a single one of the scenarios I ran through my mind.I slid the whole hoist and truck across the floor in the lowered position using my tractor.
Use a piece of ½" thick flat stock of the correct width and slightly longer than the mount as the spacer?I got the radiator support/front spring hangers installed first. Those were easy to locate because I found a common hole at the front of the frame horn on both frames, and that hole lined up with the support strap on the inside of the rail. I lined that up and then opened up the existing holes in the rails with a die grinder.
View attachment 79114View attachment 79115
Once that was done I could bolt the bracket to the frame and use transfer punches to locate the other holes. Pretty straightforward.
View attachment 79116View attachment 79117View attachment 79119View attachment 79118
Once those holes were in place, I could use those to find the hole locations for the first two crossmembers. The first crossmember needed some trimming to fit because the 2wd frame bumps in at that location and the 4wd frame does not. I got it all in place on the bottom, but I need to make some 1/2” spacers for the top so it can attach up there…..however, I’m going to wait to do any of that until I get the frame mods for the motor mounts figured out.
View attachment 79121View attachment 79120
The motor mount brackets need the frame rails to be 1/2” taller….this will be the next challenge I tackle.
View attachment 79122View attachment 79123
Once that is done, then I need to make the holes for the rear spring hangers for the front springs and then the frame will be a 4wd frame.
What about cutting down the top of the mount bracket. Then just weld a piece of flat steel across the new top height. If you have 1/4” plate steel, cut out 3/4” in height. Weld it on, then it will fit. Basically cut where I drew the red line.
Wouldn't that DROP the height of the top of the motor mount bracket and thus also drop the height of the motor ½" and then cause turbo down tube to frame clearance issues, as well as probably engine to front differential/steering linkage clearance issues, too?
