I've been busy with some house projects lately, so I haven't made a ton of progress on this truck in a while. Sunday I did get a few hours to work on it and I ended up with the long block pretty much assembled.
I got the heads installed using +.010 head gaskets. I cc'd all of the pieces-parts and decided the +.010 gaskets were where I wanted my compression ratio to end up:
Combustion Chamber: 7.7cc
Pre-combustion Chamber: 22cc (using my custom machined precups that are a little larger than Diamonds)
Piston Dish: 3.5cc
Piston-to-Deck: .85cc (.004" below deck since this short block has -.010 pistons)
With that data, as well as the known volume of the cylinder being 810.34cc I worked up the compression ratio with the 2 gasket options.
With the standard thickness gasket (9.31cc) I got 18.76:1 for the CR.
With the +.010 gasket (11.53cc) I got 19.67:1 for the CR.
And then, just for funsies, I ran what the CR was before with the -.010 pistons and +.010 gaskets, but the stock combustion chamber volume (5.8cc). That calculated out to 19.53:1 for the CR. So I had somewhat of a baseline.
I decided that I would go the 18.76:1 route. This gives me a little more volume for pushing it in the future as well as a little more clearance for carbon build up.
In the same vein of preparing for pushing it in the future, I got some Comp Cams pushrods to complement the valve springs from Chris. I used checking pushrods to check for optimal length at .050 preload. Perfect would have been 8.7625 for the Intake and 8.775 for the Exhaust (stock pushrods are 8.8215", but this is checking using the Harland Sharp roller rockers....). I looked in Summit's catalog and found they had some beefy .135" wall ball-end pushrods in 8.78" length with just a couple day lead-time, so I ordered those. The beefier wall of these pushrods and the better springs from Chris should really improve valvetrain stability/accuracy.
I still had some time after torqueing the rockers down so I worked on cleaning up some covers. I got the valve covers, oil pan and front cover installed. Hopefully in the next few days I can get some more stuff installed and then slap paint on it.
