Husker6.5
You are most certainly welcome, sir!I haven’t seen these in years, thanks for the refresher!
That was one of my initial thoughts as well (if I'm understanding what you're describing), but then I needed to figure out cuts in the jambs that would be easy to grind the welds flush on later. What I didn't show in the pictures is that the top of the patch panel is even with the bottom of the opening in the door - I'm thinking about just using the top of the patch as the cut line on the inner panel of the door. That way I just have to weld and grind the 6" or so of the door jamb on each side of the opening and not the whole 36" or whatever it is that the entire width of the door is. I need to double-check the patch and make sure it has all the features there and in the right places, but when I was dreaming about this overnight, that was the direction I was leaning......Hard to describe it, but I'd cut the old inner panel straight along the step down line above those four big dimpled holes. Basically, along the line being made by the bottom edge of the new inner panel as you have it laying in the last two pictures, so that lip at the top of the new inner panel would overlap the 1" or so of the old inner panel that's left hanging down from the cut. You would have part of that upward curving emboss on the hinge side overlapping between the two, but who'd notice since the door trim panel would be covering all of that, same with the horizontal overlap seam, anyway?
Well, it definitely looks like you've committed to a course of action. Full steam ahead!
Looks better already IMO
Remember, Nate, it doesn't have to be all be perfect, a good portion of those patch welds will be hidden behind the door panel. Unless you're so Type A Anal-Retentive that just knowing that spot welds lurk behind your door panel will keep you up at night and a year from now you're popping off the door panel and finishing the bead, DAing, priming and painting your farm beater.![]()
What I have learned so far about you fixin trucks n stuff. If you think it might work, you will make it work at an excellent level. In fact, I’m starting to think you have to show us a mistake somewhere that turned out bad so we know your not just tricking us all the time! Haha. Chef Ramsey, Martha Stewart, and Nate...
Now, about that skid steer. . . .![]()
You'll be happy to know that I've been redesigning the retaining wall project and I'm probably going to be able to do it with the Turd Ferguson instead of the skid steer. The pressure's off and problem solved!!Now, about that skid steer. . . .![]()
