schiker
I have thought about a little cooler like an ATF or oil cooler tube and fin style so it would be low restriction. For the ATT that is all that might be needed for heavier boost situations. Not really trying to chill the IAT. Just something to reduce IAT down to about ~150F. Just something to take the air heat off the radiator because any boost over ~200F will just add load to the radiator load. Probably wouldn't even have to run the water pump unless towing??? Tank being a radiator under the bed area. Maybe some copper tube and a frame rail type cooler in the back area.
Have also thought about some copper coil wrapped around the intake runners to try and wick some heat out too.
I
I
