Husker6.5
So running stock tune on it still?  Any possibility before changing the tune of getting some MPG numbers to see what just putting the ATT on has done?
Appreciate that. Can't find it in your signature, but assume 4.10 gears in the K3500? As you can tell from my post comments on various threads, I'm not so much interested in massive HP gains for towing mega loads as I am in finding the combo for maximum MPG for highway cruising with my K2500 Suburban. Obviously, turbo efficiency plays a significant part towards achieving said efficiency.
I thought it was in the sig, but I'm running 3.73's.
Reread it again. Nope, everything but. 3.73 same as the Burb, which will give me a good ballpark idea, although I'm contemplating 3.42's front and rear for better mileage. Would love to go 3.21's, but evidently they don't make them for the 9 1/4" IFS, just the 10.5" rear. I'm aiming for 1800-1900 rpm @ 75-80 mph without going to really tall tires (air resistance) or a Gearvendors OD unit ($$$$$ w/4WD). Any way, will give me a ball park idea how much just swapping out the turbo would make for a difference.
As far as updating your 94 interior to 95-97, I can tell you from my own experience with my '94 Cheyenne C&C that '95-later seats do NOT fit in '94-earlier cabs. I bought a gorgeous '96 blue cloth 60/40 split bench with head rests out of a Silverado at a parts yard to replace my vinyl blue straight bench only to find out that nothing fits after yanking the old bench seat. On further checking at the stealership parts department, GM changed the floor pan stamping between the '94 and '95 model year. Mounting bolt holes don't come close for either the 40 individual seat on the passenger side, or the 60 bench with fold down console on the driver's side, the transmission/transfer case hump is different and interferes with the later seats (especially the 60 bench), WAY too much fabricating to make work AND safe. Easier to go with an aftermarket like Trail Boss and use their mounting brackets. As far as door panels go, don't know if all the clip holes are the same.
Yeah, I've pretty much given up on the idea of replacing the interior, I should remove that from my sig.
I would still like to see if I can find some captain's chairs from a suburban, though. Same year is is fine at this point.
The biggest thing for me is that there are a few components that i need to replace on the interior. The driver side door panel and all of its components needs to be replaced as well as the trim around the dash cluster. I haven't yet found a door that's complete at a wrecker and it's prohibitively expensive to order it from someplace like LMC.
Oh the joys of parts yard scavenging, especially when every one else is looking for the same part(s) as you. Well, there's always the spray can of vinyl dye if you find a good panel but wrong color.....
Biggest problem is that people tend to just rip the panels off without trying to remove them correctly. I also need the underlying framework. So far I haven't been able to find any in usable shape.
Typical two steps forward and three back stuff.
