turbovanman
I has boost, :O)
what's the gauge under the boost gauge?
IAT, it stops at 225 deg F.
I want another one but with EGT and boost, I have to save up, its around $200.
brand?
Very Impressive! That big truck will flat boogie.:thumbsup:
Matt
Sucks to read but I know the feeling, I did what you did for years with my Caravan until I had enough, she's been sitting for 2 years and most likely I'll fix her up over winter and bring her out fresh for drag racing season.With it not being my daily driver, I can fix her up the way I should have years ago.
Don't denigrate your ride. That thing is very impressive and then you add the fact that it is a HMMWV! If I needed another project or two, I wouldn't mind making one of them a H-1.It is what it is, and when it's done it will be worth it.
In the meantime- if you miss driving a fast 6.5, well I can't help with that. You are welcome to come drive my slow one again though. Maybe I'll actually get something done to it by time you see me next, other than the 3 tires it's eatin since the last time and my prius guard build.
Much appreciated, your work is very much admirable too. Then you add the cost factor in and your ability to make nickles squeal and then squel some more...Dollar for Dollar, your results are even more impressive.You do nice work Paul, and I look forward to seeing your progress. Although, I will miss the videos while your truck is down. :thumbsup:
Matt
