ak diesel driver
6.5 driver
Don't waste your money on anything but 60gs or duraterms and yes volt drop sounds about right
the 60gs and duraterms are self regulating so a manual glow control will work just fine.
The glow plugs are still my bet, especially since the previous owner used ether.
How exactly did you test the plugs in the block?
If you were testing for continuity - one test lead to the spade connector on the glow plug and the other to ground and had no reading that would indicate a bad glow plug. No continuity = bad glow plug.
Does your tester have a buzzer?
At this point with the info about the ether use, you can just switch the glow plugs and skip the testing.
That's a good price on 60G's.
My 95 wouldn't start found out there was only two glows that were working, even plugging it in on a 70 degree day wouldn't make it start. Bought some Bosch duratherms and put them in and she fired right up. Rock Auto has them for $7.67 ea. plus shipping.
Mark
Did it come with a cross-over pipe?
It's just the exhaust pipe and muffler. So I'll need the crossover? Anything else?
#8 is the hardest I did mine from above
My tester doesn't have a buzzer so I set it on ohms (cheap pos). I went from the spade to the manifold and got no ohm reading at all on 3 of them on the driver's side. After I checked those three I called the guy to see if he knew when they were last replaced and he didn't know. That's when he told me about the ether and I started pricing the plugs. The 60g's I found a dollar cheaper at O'rielly than the autolights at advance or autozone.
