Matt Bachand
Depends on the 6.5
Installed my Walbro FRB-5 and Racor 490R30.
Everything seems to be running fine, however, I only have about 4psi at idle.
They way I wired this was took a pigtail off of another stock LP, and wired the hot lead to the red wire on the walbro, and the black (ground) to the torq nut on the walbro where the black wire is mounted on the walbro.
Is this wired up correctly?
Wondering why I only have 4-5psi.
I feel it do a pulse like series about every second. I cannot even come close to hearing it. I did mount it directly to the framerail with a 3/8ths solid piece of rubber mat in between.
I can see the pulses in the fuel lines, and feel them forward, and all the way back to the racor.
Did I wire the pump wrong to cause it to only output 1/2 of its spec?
Before I did anything I hooked my temp fuel pressure gague up to t-valve and AC Delco pump at idle read 7.
Now it reads 4. Havn't road tested it (still jacked up and raining), but I expected alot more.
I don't see any leaks anywhere.
Any Ideas?
Stamped right on the Walbro says 10psi. Seems odd I'm getting exactly 1/2.
Any Ideas?
