Missy Good Wench
Wild Blonde from Cloud Mt
O have a Racor 230R2 filter mounted on DaHooooley. I made a bracket and bolted it to the inner fender using the two front bolts on the ABS module right alongside the alternator (95 Truck)
Used the stock lift pump and feed from the pump from through to the Racor and then jumper over to the IP.
The Racor has its own drain/water bowl and a heater is available if need be..
One needs to use a 2 micron filter ahead of the IP to be sure to keep the IP healthy.
If you get into marginal fuel quality a primary filter of 10 micron may be in order too.
The factory filter is way too small and also a mess when changing filters along with being a tad loose on the microns.
The factory filter will keep out dead birds and large rocks.
The 2 mic will keep the IP healthy.
The nice part of the Racors is that one can observe the bowl and see of there is any water or crud
MGW
MGW
