Matt Bachand
Depends on the 6.5
Seems like your PSI w/ the Walbro is about as good as a 93 HO pump.
Which apparently is more than needed. 4+ anytime is well within spec.
The difference is, when pulling hard the 93 HO pump will drop in psi, where as the Walbro just keeps up with the flow with little PSI or volume drop-off.
Walbro is also made to survive a lot better with a non-rusting aluminum housing. Not the the little rusty can with fuel lines attached to it resembling more of a gasoline inline fuel filter with a harness connected to it than a lift pump.
This is also pulling through any pre-filter of your choice, which that alone isn't recommended with the 93 HO pumps.
All for a few bux more, with little fabrication required.
Still wish I had 10psi or so though. I like the thought of the IP opening and the fuel just getting jammed in there.
