How do you carry the blade when your driving ? I have found straight and low as possible has worked best for me so far. Problem with our trucks is they sit so low to the ground that you can't lower the plow enough to get air in. Even the gassers have the same problem. The town trucks do the same thing on the highway and they are all gassers.
I do have a ziptie chained to a certain lnk so I can hook it up for highway use, leaving it barely off the ground.
But, Last season i put a brand new 8" cutting edge on it,
meaning i can't leave it low enough
and, it's a 9' so if I leave it straight it sticks dangerously far out on each side, not to mention over the 8'6" limit for width... Then when I need to angle it to maneuver around/tight spots, it drags considerably when its that low.
Not to mention I fear it catching on manholes/cracks when hitting bumps as trucks do sit very low.
My plow has been severly welded too, which increased its already heavy weight another couple hundred pounds.
My new skins will prbably net me an inch higher, this year.
Also, I'm not sure how much engineering goes into airflow on plows, but my entire face/top was re-constructed via weld, so not sure if that changed my airflow or not from a factory setup. Its a Fisher 9'.
Pretty sure SuperDuty clutch will engage in time for me. Its not like I even go fast with it on, it just blocks all airflow, and I have a few nasty hills that I need to climb without any logical way around them to get to certain customers houses, brother in-laws specifically, so i can't blow him off either, as thats where I always fix my truck with supervision of his mechanic which works out of his yard. (The guy that fixed my head)...(and screwed up my injectors, lol)...
