Acesneights1
If it was 400$ it would be worth it IMO.
For special applications this is sweet.
I made one up and have it sitting on the shelf. The only reason its not on the rig now is that I have yet to work out the final details of keeping the AC system working when the fan is off.
Need a port into the AC high side to activate the fan when pressure exceeds 250PSI
Also really need some air constantly for the AC condenser to work right.
My Kennedy fan clutch disengages just fine, and it definitely helps out here in the desert.
Think it would cost that much ?
but I truly believe if you could get that clutch/fan setup out the door for under 5 beans, people would buy it. I'm not rich and I would in a second.
Happy now?
Why not remove the mechanical fan all together and install electric pullers?
Hook them to a toggle switch?
Well as Robyn said the part alone is $500 plus all the running around doing machine work, misc parts, labor, RISK, everything considered. Don't be offended, but just to make the point, you are willing to pay $500 for a turn key mod, well the parts cost more than that. So thats why I think no one would by this mod at a price that would make it worth the manufactuers investment.
Thanks, I've been here a while, I am a transplant from the other place. I have cut my internet time way back.
Here is another option.
The older HD gassers (3500 and some 2500 trucks and Burbs with 454) would spool up the fan as soon as the water temp crept even close to 210.
They howled like Hell but the engine temp dropped like a rock even at high ambient temps.
The other issue is that if the heat can't get out of the water (radiator core skunked up) the fan clutch will not see the heat and will not engage.
A new Visteon radiator is $245 at the rad shop here locally.
Best $$$$ one can spend on a rig with high miles.
Dump the coolant and flush, replace the radiator and refill with clean green and go.
This might be a dumb question, but without the two to compair next to each other I do not know the answer. Question is, can you put the gasser fan clutch on the 6.5?. Pro and cons?
