NVW
I appreciate that Leroy, I truly hope someone in need wins.I hope Leo wins the Christmas giveaway!
He gets two thumbs up and a "Bingo" for now
#9998
#9998
i picked up 4 push rods, complete rocker assembly, 2 lifters, 2 bent washers and 2 hold down bolts from Wes today. he's a great friend and always seems to help me in one way or another.......@deejaaa do you need a couple pushrods, or do you have some?
yep. not what i wanted to see. main reason i was holding off. ........you have carnage thread entries! ......NOT have enough cranking RPM. Flat batteries, half the starter failed, cables, engine locking up...It's possible the bolt broke and the pushrod slipped to the side of the rocker, bound the valve spring, then bent......last 6.5 with bent pushrods.... shattered a piston at TDC.....rotate the engine....by hand....to make sure the valve isn't seized or hitting something. Then....compression check.
i will do that next, thanks.Put air in the cylinder and listen for air leakage in the intake runner and or exhaust. My bet would be on a bent valve.
between the vids, rigging a pressure tester, dark skies........i'm really not sure what i remember or did or what it did.....i'm a diabetic and my sugar was dropping also.So it held pressure or just none leaked out the intake or exhaust? Other place to check would be crankcase (bad rings or piston broke). Also check and make sure valve is getting full lift. Possible bad cam (unusual).
yeah. i hope not.I suppose a bent piston rod might lower compression too.
