Big T
Was that just rotors/pads "new brakes" or were calipers and hardware (boots, clips, slider pins, bolts, etc) part of that, too?
New rotors, new pads, new clips. Greased slider pins.
This is the kind of heat exchanger I plan on using for my next WTA install. I’m just trying to decide whether I want it in front of or behind my AC condenser, since I’ll have AC functioning.Started fitting the heat exchanger. Going to use some scrap aluminum angle I have laying around and rivet nuts to put it in the core support between the oil and trans coolers and radiator. Should I fill the holes in the core support that the old CAC used to pass through?
I’m not sure if there’s a benefit either way for the holes in your core support, as long as they aren’t affecting the seal of the radiator and fan so air gets drawn through the core and not around.
Yeah, it probably wouldn’t take much more effort…..though as I think about this more this morning, I think the orientation I would choose is (from grill to engine) intercooler heat exchanger, then condenser and then radiator. I think the heat off the condenser would affect the temperature of the heat exchanger more than the other way around, but that’s just gut feel. Of course that orientation would take more work because I think the condenser would have to be set back more than stock. It will probably also take changes to the trans and oil coolers as well. It’s all doable, it’s just a matter of how important it is to someone.O Ed fgfcbbbn,;
I guess I could put in a little more effort to make room for the condenser so I could get AC back, but that will be for down the road.
I wonder when someone will develope a spacer to fit behind the headlamp buckets and also that would have another molded piece that would fit the front clip and the grill screw to that.O Ed fgfcbbbn,;
The grill spacer could be painted to match the vehicle that its to be mounted onto.I wonder when someone will develope a spacer to fit behind the headlamp buckets and also that would have another molded piece that would fit the front clip and the grill screw to that.
Even something two or three inches or so thick to make room behind the grill for a CAC.
oh no, I know what you mean, I have been on the receiving end of that! I do need to adjust my lights. not sure what moved but the other week I hit a bird on my dirvers side headlight. the housing looks like it hasn't moved, but shining on a wall I can tell there off now.Please don't be one of "those" people who don't care if they blind oncoming
Traffic as long as you can see better. LEDs can be done without blinding others.
Please don't be one of "those" people who don't care if they blind oncoming[QUOTE="dbrannon79, post: 620857, member: 277
for headlights, I installed LED bulbs in the OE housings. also used a cleaning kit to clear them up. them things are bright! I can tell others dont like them because I get flashed all the time at night! I just flash back then they turn theirs back on low lol
I have more than once thought about that very thing when considering doing an air-to-air CAC on my Burb (still debating whether to use the 1st Gen Dodge 5.9 Intercooler I have and mounting in front of the cooling stack, or using the 1st Gen D-Max Intercooler I have and doing the stack set back install @THEFERMANATOR did, or using the D-Max unit out front of the stack. My solution to the grille issue was to use about 3" long tubes as standoffs and use appropriately longer screws to mount the grill with. Then possibly fabricating some ABS sheet 'filler panels' to fill in between the grill and fenders for visual continuity. Or not if I decide to make a custom front critter bar front bumper and carry the headlight protector bar out and over that gap.I wonder when someone will develope a spacer to fit behind the headlamp buckets and also that would have another molded piece that would fit the front clip and the grill screw to that.
I have seen that option too.On my 94 C3500 that I used to have, I mounted a cooler (27"x12"x3") at an angle under the bumper, routed the hoses up through the the corner of the inner fender and then to the turbo and intake. Used a "marine intake adapter" on the engine. Universal piping kit from eBay and a couple adapters. I was worried about the angle mount and the possibility of it getting damaged but I never had an issue with either. It worked better than I could have imagined!
I was going to build a guard on mine to protect it. You could make it removeable for the summer and winter time it wouldn't need as much air flow to work anyway. Especially in Montana!I have seen that option too.
Problem over here being, I like to go winter fishing through the ice, many times there is deep snow drifts to plow through.
I would be in fear of destroying the CAC in such an event.
Not to mention hitting the occasional 25lb raccoon driving down the highway at night at 65mph (accidentally hit a big ol' male raccoon one night at 60mph with the G20 conversion van and tore off the front passenger aluminum mud flap from the inner fender well and bent the crap out of the front 2' of the extruded aluminum running board it was still barely attached to). Not to mention off-roading and taking a log/rock/dirt hit to a skid plate location mounted CAC. That location is ok for all on-road, fair weather climate driving.I have seen that option too.
Driving to Billings one night, wifey cruising along about 75 MPH. Interstate 94, west bound.Not to mention hitting the occasional 25lb raccoon driving down the highway at night at 65mph (accidentally hit a big ol' male raccoon one night at 60mph with the G20 conversion van and tore off the front passenger aluminum mud flap from the inner fender well and bent the crap out of the front 2' of the extruded aluminum running board it was still barely attached to). Not to mention off-roading and taking a log/rock/dirt hit to a skid plate location mounted CAC. That location is ok for all on-road, fair weather climate driving.
