If they didn't put sealant on the studs it's guaranteed water will pass through... of coarse you already know that... drain the oil....
Dont need to totally drain the oil to check for coolant.Getting a pretty good oil leak from the front of the engine. The shop that did the heads put in a new front main seal when they did the fluidampr, hoping they didn't screw it up.
Another big concern I have is they didn't put sealant on the studs before threading them in to the block. I checked the oil and it is well above the full mark on the dipstick. Im theorizing they overfilled it when they changed the oil after the head change and its leaking past the seals. Im half tempted to drain the oil and look for coolant too, just to ease my worries.
Damn that's a long change interval!225K miles on the ‘99 Suburban and changed the oil.
Damn that's a long change interval!![]()
Yeah, the ends of those return hoses that push onto the metal return wye can get crunchy, split and leak, or perhaps one isn't seated over the nipple completely. Could also be an unnoticed nick/cut in one of the hoses that could be seeping, too.
Been driving the truck, still getting a drip from the front of the motor. As dark as the drops are I was thinking oil, but after a while the drops are spreading out thin so now I'm thinking fuel that is picking up oily residue from grime on the front of the engine. I'll be looking at the hard fuel return line at the front of the engine.
