Husker6.5
Shhh! You're giving away the secret to his new methane injection system for his truck!
Yes, many of us can relate.
On the glowplugs, hoping ac delco 60g. Remember to use the antisieze on threads.
If you haven’t already ought the rubber body pulley to go with the new balancer, and since your balancer is now a forever item- check out this:
.Leroy Diesel
leroydiesel.com
Too bad he doesn’t have anymore of the gear drive timing gears while you are there. I would suggest a new chain while you are that far into it.
.Leroy Diesel
leroydiesel.com
I once had a 1976 FKH Electra Glide Harley Davidson, 74 cu inch with a couple of hot rod components installed.Both of my 6.5td's would run like raped apes on those cool (35-45°), foggy mornings. Combination of cool, dense air and Mother Nature's water mist injection! And of course, those nice, crisp -15°F mornings when the air was nice and dense they had a little more power than usual, but it was those cool, foggy mornings where it was really noticable for the power increase at WOT getting up the on-ramp first thing in the morning.
Leroy Diesel has a facebook page. Someone over there started a list of who would want to order the timing gear set if He had more of them produced. I got My name on the list.Yes, many of us can relate.
.Leroy Diesel
leroydiesel.com
That should have been a FLH.I once had a 1976 FKH Electra Glide Harley Davidson, 74 cu inch with a couple of hot rod components installed.
Those days when there was a heavy mist in the air, that thing would run cool and get up and roll like it had turbo boost. What a blast. LOL
Crawled around under the Tahoe to see what is squeaking...... Looks like I need A arm bushings and will do the ball joints while I am at it....
I am looking at the MOOG vs MEVOTECH vs PROFORGED on RockAuto for the ball joints.....
And was eyeing the Energy Suspension Polyurethane bushings....
Anybody have an opinion?
More air than needed in the air/fuel ratio at all rpm's is ALWAYS good for a diesel! More complete burning and combustion efficiency equals more power, cooler exhaust and less stress on the engine all things being equal. Remember, it is the VOLUME of air (CFM), not the PRESSURE (PSI) being delivered that is important. Pressure is a function of volume being moved through resistance to flow (the smallest opening, like a runner or port opening) or reduction in volume in a closed container (ie: piston moving up in cylinder with valves closed). I don't remember the details of your build, but at stock CR 18psi is near the upper limit with a GM-x turbo and stock motor. I would rather have a high volume, low psi turbo easily feeding my diesel enough air; than a low volume, high psi turbo struggling to feed my diesel enough air at X rpm for many reasons.
Right! I want to (eventually, when I have money again, whenever that might be) put either one of those, or the VGT off a Duramax (preferable because of the engine displacement being near-identical to a 6.5, and it keeps the ride "All GM") on my Burb to get better bottom end and cruising power below 2100 rpm.
