Husker6.5
Well, @Paveltolz, just think this. That kid behind the counter is not only the future of this Nation, but humanity. Be glad that we won't be around for the results.
It’s not the distance, its the company.Ten miles to get to the next AZ parts store. WOW.
Ten miles here, in any direction, puts You a good distance from anything besides farm or ranch land.
Three parts stores in town. All three maybe a mile and a half, two at the most, and all three within a 1/4 mile of each other.![]()
When I was working at the back of the engine, laid a 4X4 block atop of each battery, laid a nice 12” plank across the 4X4s and then I was able to lay on the plank and reach the electrical connectors at the back of the engine to scrub each one of those clean.Replaced the Optima Red Tops and, ‘since I’m in there,’ decided to re-do the OPS/Turbo Oil Feed T set up.
Since the block is a 660 (N/A) it doesn’t have a port in the valley for the OPS or one up front for turbo oil feed.
There’s only one “convenient” port…in the back…behind the driver’s side head an inch away from the valley and a couple of inches from the fire wall…under the Glow Plug Relay. Easy to get to when the engine is out and sitting on a stand. Not so much once installed. Wheels off, resting the knuckles on 2x4’s with the hood off helped with the gymnastics but, still a fine definition of ‘royal PIA.’
I went fancy after initially using brass but, it turned out the fittings weren’t metal and didn’t provide a path to ground soI had to cobble up a ground wire for the OPS (1996 means no ground= “no oil pressure” so, no fuel and no start).
The fancy assembly had started leaking enough to mark territory and with the weird starting issues I had tried to re-do things earlier this month. So I suspected the recent attempt to correct things neither fixed the leak nor made a good OPS path to ground.
Old set up (ground wire removed).
30-40 minute flexibility and agility test getting the 45* fitting at the port.
90* fitting thread into place. Another agility/leverage battle.
Brass set up
With new Optima‘s and correct OPS set up, the engine spun so fast, like the glow plugs weren’t in, and it lit in about one second flat.
Two more ‘to do’ items off the project list. Down to less than one page with the 4x4 actuator circuit diagnosis and repair being the only real ’priority‘ item.
I gave up on brass fittings after Will said they don't hold up to the new diesel.Replaced the Optima Red Tops and, ‘since I’m in there,’ decided to re-do the OPS/Turbo Oil Feed T set up.
Brass set up
Yep. I never know what I'm going to end up using any fitting for. Could be anything from air to potable water. So stainless has me covered.Brass is fine for oil- just not for fuel.
It wasn't laying on top of the motor so much. I had thick rubber padding for that. It was climbing up and down so many times. Too many miles with a pain bag on my back after parachute jumps. Body just doesn't do 'flexibility' so well these days.When I was working at the back of the engine, laid a 4X4 block atop of each battery, laid a nice 12” plank across the 4X4s and then I was able to lay on the plank and reach the electrical connectors at the back of the engine to scrub each one of those clean.
I dont know how well that would work in Your situation but it sure made it comfortable for the situation I was working on.
Do they ask for gender?AZ is famous for asking all the questions when your in there getting something for your tractor or farm equipment. LOL I have never seen a real parts man in there! One who you can just walk up to the counter lay the old one there and they know exactly what it is and not have to open a computer or book to get it! ( of course anyone at AZ don't know what a book is) in my home town they have a famous name.... Vato Zone!! every low rider in town including cheech n chong will be there on the weekends with their hoods up and up on jacks pulling engines and what not!!
No that’s probably discriminationDo they ask for gender?
That’s a blood trail during fall deer hunt.Welp... here we are again lol. I decided to look at the truck checking to see what a popping noise was as I turn the wheel to the right. didn't seem to find anything but I discovered my truck had eaten yet another idler arm bracket! time for another replacement.
While I was under there inspecting random things, I looked over the new power master starter and it's mounting, that all looks good no issues there but I found a new oil leak!! at first I thought it was the front crank seal again, but looking at it from the side, the timing cover in that area seems dry. this one is the very front of the oil pan. I attempted to snug up on the two pan bolts to make sure they were secure. it's slowly looking more like I am gonna need to pull this engine and re-gasket everything as some point. here's a couple of pics. The last one is the puddle it's made sitting there for maybe 30 minutes with my thumb next to it for a size comparison.
View attachment 82565View attachment 82567View attachment 82566
