94K30
Diesel nut
Keep the dodge and CUCV and sell the 94':thumbsup:
X2..... a quick fix up on the 94, then sell it
My only issue with motor fulshs is sometimes it's better to leave sleeping dogs lie...No tellin what ya might loosen up.....
My only issue with motor fulshs is sometimes it's better to leave sleeping dogs lie...No tellin what ya might loosen up..... Wanted to work on the fuel leak but I got started welding the floors in my big rig and now I'm commited(and should be !!)
What I do not recommend is that compression restore stuff, I tried that, another reason I want to flush the system.
I loosely toyed with the idea of ripping the cab and nose off and putting it on the CUCV. Then I reminded myself that I'm not 20 yrs old anymore. My wife hates my trucks, all my trucks except the Dodge. she was the one who liked it. No wonder it's been a POS....![]()
True...She's got pig flu right now, I told her to go visit her mother. That didn't go over well...![]()
It's primary purpose is to destroy nature, run over a'holes and bring me home firewood...![]()
My understanding is that Auto-RX is a very dilute, slow-acting solvent. It takes 5000-6000 miles of driving to remove deposits, the idea being that the deposits end up being very slowly removed, and filtered out by the oil filter.
-Rob![]()
Ouch! That sounds nasty.I have a neighbor that is restoring a 1963 Ford falcon. It has the original 170 CI 6 in it, and he tried Auto-RX to clean it out, as the instructions called for.
I was standing there when he started it up after the last drain and fill with fresh oil. The motor sounded like it had no oil in it, and had NO pressure. He shut it down after 20-30 seconds. Pulling the oil pan showed that the inlet screen to oil pump was so clogged up with deposits, no oil was getting through. After swapping out the oil pump, cleaning out pan, etc.. oil pressure is fine, but still has the blow by coming out of the draft tube constantly.....
Kenny, if you've been married as long as I have, you may finally be realizing that the truth is, your wife doesn't really hate your trucks. See, Kenny, after being married a long time (to the same woman)... Your wife actually just hates you... So thats the good news. YOu get to keep the trucks.
