Acesneights1
Well I played around with the 94 today. It has issues. I plopped a new PMD on courtesy of Fermanator. Code 56 is gone but truck still dies. feels like it's losing prime, then I notice a large amount of fuel leaking from roughly by the FFM. Probably the FFM. Most likely have to pull the intake to see what's going on back there but here's the thing. She's gotta some blowby. Pretty healthy amount. I pulled the CDR tube out of the Air INtake elbow and you could run air tools off it. I mean nice steady pressure coming out of it. I blocked it with my thumb and felt it build up a psi or too. Motor doesn't seems to smoke. PO says it did burn oil. Truck isn't in too bad a shape otherwise but it is a 1/2 ton. Shuld I fixer up and sell her, Cut 'er up for parts for the CUCV or sell the cucv and fixer up. That blowby is really putting a damper on my motivation to fix the 94. Truck also need a PS hose(the expensive one with cooler) all new tires, a wheel cylinder possibly two. Body's not bad for the age but chassis looks like a 15 yr old New england Truck.
