n8in8or
The main difference that I can see is the passageway in the passenger side of the pump. Oh and of course the Hummer pump has the second small outlet on top.
I've read about the bypass restrictor, but not enough to know exactly what it is. Would you mind elaborating?I'd like to know what if any difference there is w/pumps, my Burb came with all the cooling mods Heath mentioned to include the HO pump I just added the bypass restrictor which I'm trying to figure was the right thing, or?
Interesting your old pump has 2 hose adapters I know one is the bypass how is the other one routed?
Generally the restrictor is the bypass hose adapter at the water pump drilled with a 3/8" to 5/16" +- hole. I made a restrictor with a 3/8" hole to place inside the 1" ID bypass hose, another way would be to block off bypass completely and use modified thermostats drilled with 3/8" holes x 3 on each stat in dual stat setup which equals to just over the 1" ID of the pump bypass. Consider I have dual heater cores which flow always and the is a restrictor in that too.
I understand the concept of warming up quicker w/pump bypass but trying to get a handle on making the most use of the radiator too as hot coolant gets dumped into the water pump intake which is generally the cold side.
Since I'm keeping the EVANS w/zero psi cap which enhances boil off of any water that may enter the system via temp change venting as steam to the surge tank I need to figure if the bypass restrictor is best when using EVANS.
Hopefully we can figure the differences pro or con.Yeah I'm not sure either. Since that pump came off a Hummer application they must have something unique in that cooling system. Maybe someone like Will L that has a Hummer can elaborate?
Yeah I find it interesting that the "better" one has a narrower passage, but perhaps it works better to have higher velocity on that side rather than flow to shove the water to the back of the block on that side? Just spitballin' here. When I take the pump off my 97 when I take it out of the truck I'll look at that one too and compare..187 wider port on the optimizer show potential for more flow. I wish we could see these going through a flow meter. When I tear mine off I might have to do some fabricating and some experimenting. So much to ponder.
I really wish these pumps were easier on/off like the old school water pumps, I'd tear into it a lot sooner. The redesign works good for you guys in the pickups, but there is no set answer for the hmmwv/hummers. AM General still thinks 230* all day long is ok, yet has short life...![]()
The driver side connects to the crossover. The passenger connects to the heater core, and when off closes flow all the way. The other end of the heater hose comes back to the crossover to the passenger side of the thermostat (left in the picture). [
The crossover is not the same single stat as in pickups. I'm thinking about redoing my whole set if I knew what crossover to get with the db2 as long as it isn't taller by more than 1". Thinking about building my own crossover if I have to. Then I could achieve the "balanced flow".
For you I would do the single that WarWagon is using, his system is alive still in that heat. Only reason I'm not 100* on it is idk height. On db2 if your DMV doesn't shut you down for it I would do it in a second. Let me count the number of problems with my fuel system- 0 done. No ds4=no pmd.
Yep, it can be a problem however many good options now that simply did not exist years ago.Now you guys have me thinking. I am never going to get caught up financially if I keep hanging out here!![]()
However, you save tens of thousands $$$$$$$$ by not having to buy a new or near new vehicle.
