If you search the flow kooler threads here- you’ll see we spoke about them and I called them up asking about the balanced flow issues. They knew NOTHING of it.
They have their twist on a pump impeller design and are making replacement units for all kinds of engines in cars and trucks with that impeller.
In the threads here you’ll notice when in their ads the LATER ADD about balanced flow. Sales pitching without actual testing anything.
Worse sales pitching to customers that haven’t worked around pumps professionally:
And they still have the thing about high head pressure. It an issue in the laws of physics.
“Head” pressure is just pressure on the output of a pump. But there is positive displacement pumps like your oil pump or fuel pump, and there is non positive displacement pumps like a car water pump which uses an IMPELLER not a PROPELLER. Technically pumps don’t create pressure. They create flow, and the resistance to that flow creates the pressure.
So actual head pressure is measured when you completely stop the flow of the fluid, then while at its median speed measure the pressure. And since this is an impeller- that number will be zero. The impeller is designed specifically to not allow pressure built from the pump. Here is why:
Engine cold, no pressure. Remove thermostat also remove radiator cap, start engine- no pressure only flow. As engine gets hot no pressure can build and at 212 you boil water away. If you add the cap- THE HEAT builds pressure like a pressure cooker on the stove.
You have a 15 lbs cap- and the engine gets hot enough with this engine to make 14 psi all by itself. Now- imagine if all the sudden you add a water pump that can add 1,2,3 psi pressure. POP goes the cap and water on the hiway!
Now think about that thermostat when it is put back in. Engine is cold, thermostat closed. Big 2” radiator hose feeding that water and it has to circulate somewhere or blow a hose off. So the impeller is designed to let the water “slip past” so that it doesn’t build pressure while cold. Most of us have seen the waterpump backing plate and noticed the pitting- its all chewed up like it is rusting away. That is not rust. That is cavitation. When you increase the flow it increases that cavitation linear. But when you increase pressure it reduces the cavitation. Why did gm go from 97 to 127 (not really the 100-130 estimates we round off to) snd not go to say 140 gpm? The cavitation is in reased dramatically. It isn’t hard to change impeller angles and counts. It doesn’t cost ten times more to do that. They had to pick how high they could go without creating a new problem.
And adding back in that thermostat- does that change the pressure that is created by the engine heat? Nope. That pressure when the thermostat is open and the cooling is really needed- what is the system pressure- is it magically higher head pressure for an advantage? Nope- it is what it is from temperature changes.
All engines of every manufacturer has always only used an impeller water pump for this reason. They cannot run a pump that is positive displacement UNLESS they control the speed based on heat and pressure generated. A modern design that would be great is a positive displacement pump, no thermostat, heat sensors in a few spot on the engine as well as water pump that feed a computer to tell the pump when come on and go off as needed for cooling.
Yall remember me talking about the testing I did years back? We removed the belt driven waterpump and used two electric driven pumps to replace it. This was on an engine stand. And we did 2 pumps not one because we didn’t have electric motors that were strong enough to drive a single pump. That electric water pump idea should sound perfect- no wasted energy, better control of cooling- even one side vs the other!
And so long as you use a honda generator in the bed it would work.
Look up electric water pumps that can move 100 gpm and notice the hp they use. You are not driving that on 12 volts anytime soon. You need a Toyota starter motor running non stop for that much power. Water pumps steal a crap ton of power even without the fan. Thats why our old school drag cars had restrictors inplace of thermostats and the electric belt driven pumps- free hp. Just enough cooling to keep it alive then cool it down in the pits. They talk about the 130 gpm now from reading forums. But never learned the actual GM spec of 127 or would have referenced it. Then they never say what gpm their improved unit is. Just “It achieves greater flow rates, higher head pressure and a more efficient flow.” Ok, last claim of more efficient? Lets say sure- because they don’t say more efficient at what drops per revolution while using less fuel? More efficient at moving money from one store into theirs is most likely.
One last thing about their snake oil slinging speak- “color is due to Type II Class II military grade surface coating” ok- plenty of military folks here. Anyone know where to look that up? That is some bs there. I mean- they already are trying to argue against the laws of physics so why not the military nomenclature as well. Look at the pic and see what is meant. Then tell me who here had their impeller wear out as the issue why they replaced their 6.2/6.5 water pump. Instead of the front seal failure that sends coolant out the weep hole so you don’t seize the bearing and have your fan be the giant ninja star of death.
If that coating is all that and a bad of chips- why aren’t they selling it on the backing plate which actually surfers the damage they are trying to protect against.
Look- I am not saying this can not work, or that it can not work better.
But a couple folks said they tried it and had less results than the AC Delco.
And this company has done some shady advertising at minimal.
And they did admit to never having run a 6.5 on-a dyno or in a truck to do comparisons testing. They said they did tests on a small car engine (I can’t remember which right now) and the “technology” proved itself so well they started making pumps for many other engines including the 6.5.
Last take a look at what year vehicles this works on and doesn’t work on. They don’t even know the interchange years.
With the known problems that experimenting with 6.5 cooling has brought about- no way can I afford to blow up an engine verifying what they think will work with what we know works- after GM spent millions trying to figure it out.
It just pisses me off when any company wants to pedal snake oil and and acts like it is king daddy when they haven’t even actually tested it on that engine enough to see their holes don’t even line up. Yeah if you do remember that part- ya might search it - but to be fair that might have been hummer forum not here.
